Out of curiosity more than anything, does anybody know the sort of life expectancy (Mileage) of the engines in the 8P?
Was just wondering about it the other day. Must be a few out there getting on abit now...
If looked after & serviced when required using decent Oil the engines should last well over 100K miles.
However, one of the problems with the (8p) & other TFSI series (Apart from FL series) engines is inlet valve coking which will start to effect power output as the engine ages!
MY17 Panther Black RS 7 Performance | Black Pack | Carbon Interior | 21" DS black wheels fitted with MPS4's tyres | Dynamic Pack | Audi Connect | Advanced Key + boot opening | Audi phone box with wireless charging | Audi smartphone interface | Dynamic Mirror Indicators | Parking pack | Feature programming changes | EM Tuning interior LED light update | Thinkware F800 pro + Rear Dash Cam |
Wife: MY12 Daytona Grey RS3 | Bucket seats with grey stitching | Heated seats | Black Styling Pack & Inlays | Black Roof Bars | Privacy glass | RNS-E | Bose sound system | Reversing Sensors | Audi LED number plate lights | EM Tuning LED interior light pack | Cruise Control | Folding, dimming & heated mirrors | Auto Lights & Wipers | Adaptive headlights | Gloss Black Alloys fitted with MPS4's tyres | Thinkware F750 + Rear Dash Cam |
Depends what you mean by life expectancy. If you exclude wear and tear items like sensors, pumps, clutches etc then with good servicing and driven well they can do 100's of thousands of miles.
If you mean a car only require oil changes, then a well looked after car can easily do 150k miles IMO.
Tbh it don't even come up on my radar mate.
It's not even really on mine tbh. Just with so few 8P's around it was something that I didn't really have any idea about.
All depends on how they are treated / Driven / Serviced / quality of service related items.
Watched an interesting clip of oem bmw oil vs Castrol Edge recently and the difference at higher temps of how the oils reacted was quite noticeable.
Am a firm believer if you treat the car right it should be ok for a long time.
The CEZB engines probably may benefit from a clean in the inlet valve tract / Valve backs once the engine gets to a bigger mileage.
https://youtu.be/r6dG2UY5xLMSean.
Tell us some more or post the link about the oil mate.
Not sure how credible it is... but it does make you wonder.
Edited by T-800, 14 September 2018 - 02:14 PM.
I must remember that if my oil temp ever gets to 400*
Neil.
400* is well beyond the working temp of what engine oil is designed for.
The synthetic oil we use will start to degrade at 140*/150* so the 100*/105* we see in normal use is well within its working range.
True Neil
It does make you wonder though if subjected to constant longer high temperatures would it make a difference to engine components though........
As the oil over heats & breaks down it will loose it shear strength & you will then get metal 2 metal contact with accelerated wear on the load surfaces & the ensuing failure of components.
My point exactly Dell.
I like my oil changed regular.
Hmmm, hard one for me to comment on my RS3 engine died at 75000km and the car was stock ... another guy I recently met had his engine fail in the same way at 86000km, same piston 4 that went first and then rest looking terrible.
When he posted his frustration on facebook to Audi S.A we had a few guys actually coming on having the exact same problem with engines that failed between 50 000km and 90 000km.
So something is not ok with the cars here in S.A or it's something as simple as dirty fuel ,because when I got mine when I changed the fuel filter it looked like coke , this was fuel going through the filter before the filter the fuel was clean ... I also recall that my fuel trims was always in the double digits and this most likely killed the engine.
Now after the rebuild and them cleaning the injectors and fitting new seals etc the fuel trims are basically always single digits close to 0.0
The Real Cvh
He of Driving Wizardry
