Brake squeak
Posted 03 September 2018 - 12:03 PM
Posted 03 September 2018 - 12:37 PM
Got reyland discs upgrade with ferodo ds2500 pads and never heard so much noise/squeals at slow speeds!! Is this normal ?
Speak to Martin/Dave at Reyland about the noise but i think your find thats normal with that grade of brake pad.
Posted 03 September 2018 - 04:26 PM
Have you fitted the shims on the front? The pads are slightly smaller than OEM and 100% have to have the shims to takeGot reyland discs upgrade with ferodo ds2500 pads and never heard so much noise/squeals at slow speeds!! Is this normal ?
up the clearance.
Do NOT fit shims on the rear.
Posted 08 September 2018 - 02:46 PM
Dell,Speak to Martin/Dave at Reyland about the noise but i think your find thats normal with that grade of brake pad.
Spoke to Martin @reyland and he has given me some advice cheers
Jonny.
Posted 08 September 2018 - 04:35 PM
Dell,
Jonny.
Jonny.
Glad Reyland could be of help mate.
Posted 16 September 2018 - 05:58 PM
Posted 16 September 2018 - 07:21 PM
Mine are the same, have a shim kit coming from Audi this week. Because I went from red stuff to DSPerforamnce, there were no shim to swap over.
Oli.
On my 8p i have no shims fitted on the back of the pads & you may find the pads are to thick to fit them.
Tbh if they needed shims Ferodo would have supplied them with the pads.
Btw i don't have any noise problem with the DSs without them at all.
Edited by RS3Dell, 16 September 2018 - 07:25 PM.
Posted 16 September 2018 - 08:16 PM
Is this 8P or 8V?
OEM 8P don`t have shims.
OEM 8V don`t have shims.
8V with Ferodo pads usually come without shims but you absolutely have to fit them.The OEM pad is longer than the
Ferodos by about 1mm .Without the shims you will get horrendous squeal.The pads will be rattling about in the calipers
Audi won`t sell them `cos they don`t use them. You`ll have to get them from Trevor.
Posted 16 September 2018 - 08:25 PM
Oli
Is this 8P or 8V?
My FDS1664 had shims supplied
They didn’t fit my caliper.
So had to wait until they wore down to fit them.
Sadly I have found my Pads now squeal with or without shims.
Trevor is talking about swapping them for the RS3 dedicated pads.
Edited by T-800, 16 September 2018 - 08:31 PM.
Posted 16 September 2018 - 08:33 PM
I don`t mean the thickness of pads .I`m talking the length is different by about 1mm.
Posted 16 September 2018 - 08:41 PM
Sean
Dunno about length Neil as mine are the FDS1664 so shims fit nicely as they curl around the top and bottom too.
Yes mate I already took them out to grind a chamfer on them, didn’t work for me.
I’ve got a suspicion the noise is coming from the lip on the disc edge
Rubbing against the out side of the pads.
Need to investigate further.......
Posted 17 September 2018 - 09:41 AM
Posted 17 September 2018 - 06:42 PM
Outer holes where easy, once passed the middle it was a different story, the dust was compacted and needed the drill......
A test drive afterwards and all is quiet which I’m hoping is a good sign, because 20 mins earlier they were squealing......
Posted 18 September 2018 - 08:35 PM
Posted 18 September 2018 - 08:44 PM
Posted 18 September 2018 - 08:59 PM
What next then ?
Get rid of the discs and go for big ass Reyland or Alcon
Am waiting on Brian to report on his 380 mm Discs......
Posted 19 September 2018 - 08:04 AM
I had brake squeal often with the original wavy discs and pads, I lived with it, as it was manageable with either cleaning them or stopping hard from speed, was never enough to get me back to the stealers for a fix that never existed.
At 30k I had the pads and discs changed due to wear, and was in 3 minds about what to do, in the end I went for OEM replacements, kept my warranty valid, cost was competitive and the results have been very good indeed.
10k on them and not one squeak, squeal or judder.
I’m really pleased with them, and reading the above it seems even good aftermarket kit can suffer the same .
And Sean - the drilling of the holes is something that was necessary on my 2010 Lotus Exige with the big brake upgrade, AP 4pot callipers with vented and cross drilled discs, the service tech explained that it was a standard procedure on any major service.
The holes can get clogged and it does go rock hard, and can cause uneven cooling = warping and cracking etc.
Audi service peeps never ever mentioned or recommended this procedure, has occurred to me a few times when having a good inspection while cleaning the wheels.... but seemed to make no difference.....am sure it will keep cooling even though.
The squeaky brake thing will be a long running and never ending issue.
Having just typed the above what’s the bet I go out today and get massive squeaking lol
OMR
Posted 19 September 2018 - 04:44 PM
Posted 19 September 2018 - 05:24 PM
SeanI actually think clearing the holes has made the squeal worse ☹️
Try converting it to drum brakes.
Posted 19 September 2018 - 06:43 PM
Pads out and I’m gonna try somethingSean
Note the edge of the pads catching on the disc lip
