Rattle on startup only when hot
Posted 22 August 2018 - 11:36 AM
https://youtu.be/6fOuyBqGfEs
I hope you can see the Vid, Audi checked the chains about 2 months ago when the flywheel was replaced and they had to fix an oil leak at the covers so while they where of they inspected the chains they look fine no play on them.
Posted 22 August 2018 - 01:56 PM
Posted 23 August 2018 - 03:15 AM
Posted 23 August 2018 - 05:26 AM
Nope the sound is coming from the chain side, it sounds like when you have a lifter making a noise and then going quiet. Sometimes it's much louder than on the video, it does not happen everytime so i am a little lost .. i did read in one of the other posts someone talked about the variable valve cams the units that can make a sound but i am not sure of how it could cause this sound the sound is not coming from the head area.
Jacques.
I seem to remember but a very long time ago there was some kind of software update with something to do with the oil pump to correct a fault like yours mate.
Posted 23 August 2018 - 06:09 AM
Jacques.
#P**sflap #2 reporting in
You are right Dell
It was originally after TTRS owners complained about a rattle on start up.
I remember mine being done after I had a similar start up noise, the oil pump was left at low pressure from the factory, something to do with the running in period I think, then it should have been switched over to a higher pressure and on some cars it wasnāt.
Whoās to blame Iāve nought idea but it was rectified in a software update.
Posted 23 August 2018 - 07:04 AM
Sean.#P**sflap #2 reporting in
You are right Dell
Thank you for that confirmation & hope it helps Jacques with his problem mate š
#p**sflap No1
Edited by RS3Dell, 23 August 2018 - 07:05 AM.
Posted 25 August 2018 - 08:22 PM
Then the engine died they did the rebuild with complete new bottom end and also the cam chains tensioners and guides. Car was perfect for about 2000km' after the first oil change at 1500km after rebuild i started noticing that when the car is hot you would get this knocking/tapping sound when you start the car ... it goes away shortly almost as if it gets enough pressure.
. It's definitely coming from the chan side .... it's a little difficult to pin point as it does not do this every time but that said it seems to happen more and more now i need to find this before November because then the 12 month guarantee on work/parts is over since the rebuild.
I send them the same clip about 2 weeks ago and nothing they just keep quiet i am also not really looking forward in getting the car booked in again. I only have one car and the car always end up standing for weeks on end leaving me without transport.
Posted 25 August 2018 - 08:50 PM
mine without messing it up.Can you get an independent to look at it.
It sounds like there is no oil getting to the valve gear.
Edited by 0120raptor, 25 August 2018 - 09:21 PM.
Posted 26 August 2018 - 12:14 AM
Posted 26 August 2018 - 11:41 AM
Posted 26 August 2018 - 05:12 PM
These guys filled with Castrol edge 5w40 i am not sure if this is the corretc oil for the car. Also i am sure they had something else in prior to the oil service at 1500km.
Jacques.
Thats fine as long as it the VAG 505/507 spec oil mate.š
Posted 26 August 2018 - 08:39 PM
What makes this so hard to pinpoint is that it does not do it every time.
Posted 26 August 2018 - 08:59 PM
Posted 26 August 2018 - 09:15 PM
Oil pressure relief valve sticking ?
Neil.
Now there's a worth while thought mate.š¤
Posted 27 August 2018 - 08:50 AM
@Raptor where is this oil pressure release valve located in the engine.
Posted 27 August 2018 - 08:58 AM
Etka lists it in long life and standard service intervals.
Posted 27 August 2018 - 09:43 AM
Hi Guys ok checked oil looks like VAG 502/505
Jacques.
That grade is used for the fixed 10,000 miles or 12 month service intervals.
I would try the VAG Quantum 5-30 505/507 oil to see if it makes a difference & its cheap mate.
Posted 27 August 2018 - 03:57 PM
JacquesHi Guys ok checked oil looks like VAG 502/505
I would imagine the relief valve is inside the oil pump.They usually are but I may be wrong.One way you could check
if it is stuck is measure the oil pressure.Remove the brown electrical connector on top of the oil filter housing and
screw in a mechanical gauge and start the engine.With oil warm idle pressure has to be at least 1.0 bar. At 2000 rpm
you need at least 2.5 bar. If the valve is stuck open you will see less especially at idle.
Posted 27 September 2018 - 03:55 AM
https://youtu.be/7My-wG_kp_0
And
https://youtu.be/6wdoZxWYaps
This is really annoying to reproduce as it doesn't do it all the time.
Posted 27 September 2018 - 05:40 AM
Ok Guys here are some better clips of the rattle i get it sounds really like a lifter sound but it's so flippen difficult to pin point as you have a very short time frame to find it and once it quiets down then you have to wait another 10min or so and hope it does it when you start the car up again
And
Jacques.
Have you had the oil pressure at start up checked as suggested by 0120Raptor i think it needs to be eliminated so you can move forward.
If the oil pump picked up some debris when the engine went bang it my be in the relief valve mate.
Edited by RS3Dell, 27 September 2018 - 05:44 AM.
