A bit of an update on the Wagner Evo3, & IAT's in general, after a visit to the track last weekend.
Pre mods setup - Evo1, WMI, engine bay openings in OEM airbox taped over.
The best track IAT I saw was 39 deg C (with fridge cold methanol mix in tank), but more often 45 deg C. Ambient temps 22-25 deg C
Post mods setup - EVO3, WMI, engine bay openings in OEM airbox taped over, additional cold air intake, dual nozzle (iced)water spray on the intercooler. The best track IAT I saw was 25 deg C, but more often 28 deg C. Ambient temp on the day was 22-25 deg C.
It's worth noting that the lowest IAT's were at WOT, with the largest amount of air possible wizzing past the sensors. Radiant heat from the aluminium manifold was having minimal impact at this time.
Certainly spraying iced water on the EVO3 down the straights made a lot of difference. If the 2.5 engine used a plastic manifold instead, I've no doubt I could have seen ambient, or even sub-ambient IATs in the same situation.
As it was, the power gain was remarkable. I had traction issues where I never had before. Also took >1sec of my lap time (a quick lap is 60 sec).
