Haldex oil change RS3 8v
Posted 09 April 2018 - 05:22 PM
Posted 09 April 2018 - 06:42 PM
Or 3 years if you don't rack up the miles......
This is what I was told when I collected mine, was the only major thing apart from regular oil services and inspections...
Mine is coming up to 31k so will be asking soon, inspection is due anytime now
OMR
Posted 09 April 2018 - 07:21 PM
Posted 09 April 2018 - 11:41 PM
Just had my haldex oil changed for the second time at 27,000 miles and just over 6 years.
Posted 15 April 2018 - 09:27 AM
My RS is now 6 years & 29k 1st Haldex oil change was at 3 years & 21k by Audi.
I've just ordered an oil filter from Hadex Spares & bought the Haldex oil from TPS as i'm changing it myself this time.
I'm also at the same time going to take out the pump to check for any debris on the mesh strainer.
Edited by RS3Dell, 15 April 2018 - 09:28 AM.
Posted 15 April 2018 - 11:24 AM
Posted 15 April 2018 - 12:51 PM
Edited by Sonnybo55, 15 April 2018 - 12:53 PM.
Posted 15 April 2018 - 05:18 PM
29k after 6 years, you need to get out and drive it Dell
John.
Too & from London for work on a motor bike
Posted 15 April 2018 - 10:23 PM
On Haldex oil change service should Audi also change the filter ?
Posted 15 April 2018 - 11:00 PM
Graham.
Audi dont change or have a part No for the Haldex filter ! 🤔
I got mine from a Haldex specialist that supplys one for the Haldex4 mate.
Posted 16 April 2018 - 08:36 AM
I asked Audi to change the filter as they don't do it automatically (heard that on here). According to the invoice I paid for a filter so you'd hope they did actually change it!
Posted 16 April 2018 - 08:48 AM
Only way they can change it is purchasing a full new pump as it’s attached to it and has no part number in Etka.I asked Audi to change the filter as they don't do it automatically (heard that on here). According to the invoice I paid for a filter so you'd hope they did actually change it!
If Audi were thorough they should’ve unbolted the pre-charge pump and washed out the filter gauze......
A big if.
Edited by T-800, 16 April 2018 - 08:49 AM.
Posted 16 April 2018 - 08:53 AM
Posted 16 April 2018 - 09:15 AM
Takes minutes at an oil change to unscrew the charge pump from its housing and clean out the gunk....Nice one T800 very knowledgeable as usual. Crazy design though and no wonder they don't change the filter!
Edited by T-800, 16 April 2018 - 09:17 AM.
Posted 22 April 2018 - 12:19 PM
Here’s what my pump gauze looked like
Removed the 2 screws and cleaned the gauze and refitted
When I had my last RS3 the dealer changed the haldex oil at 21k and the pump failed at 24k
The theory is that cause the pump sits slightly lower than the drain plug all the crap tends to gather around the pump and block the pumps supply of oil.
Loads of people suffer pump failures after having the oil changed. I’ll be doing my own within the next few months and removing pump and cleaning the gauze.
I think the haldex system does have a filter but not available from Audi parts as they say it’ll never need changing.
Posted 22 April 2018 - 05:10 PM
Posted 22 April 2018 - 05:14 PM
Once refitted and refilled it’s better to give it a short drive and recheck the level.
Usually takes another 100 ml or so once the pumps bled through
Posted 22 April 2018 - 05:56 PM
Yeah drain it then remove the pump and it’ll drain a little more then.
Quattro.
If you have VCDs you may be able to run the pump up instead of going for a run.
I will be giving that a try when i do the oil & filter change with in the next few weeks.
Posted 22 April 2018 - 06:00 PM
I changed the haldex oil on my Golf R at 15k and 18 months old.
Quattro.
By the looks of it changing the oil don't remove the crap but removing the pump will do.
Posted 22 April 2018 - 06:31 PM
Yeah I think replacing the oil makes it worse as all the crude then gathers around the pump.Quattro.
When I done mine I just popped it in to D on a 2 post lift and all 4 wheels drive then rechecked the oil and topped up.
The vcds would be an excellent option for anyone doing this on the floor
