Front differential issue?
Posted 05 April 2018 - 05:26 AM
I understand one of the 3 sides of the box is input and 2 output. I don’t know which way round it is, however I suspect it bolts to the gearbox in the orientation shown on my photo. If that is correct then that part of the shaft sticking out on my photo is what engages with the box in some way shape or form. As I tried to explain above, it was this part of the shaft that was showing signs of deflection on rotation. If this has been engaged with the box and has been spinning off centre for thousands of miles, I suspect this is what has caused the ‘downline’ damage. I don’t know for sure what part of the box the splines of that shaft fit into, however as discussed above I suspect this is the front diff.
Posted 05 April 2018 - 08:18 AM
Does this look any clearer ?
The Etka parts drawing does suggest the Shaft 14 passes through the bevel box......
vag_dsg_calibration_for_audi__vw_1_20131005_1984730453.jpg 89.58K 7 downloads
Posted 05 April 2018 - 04:22 PM
The diagram T-800 has shown is very different to that which you have shown and ‘looks’ to better reflect the physical box. I understand what your saying with regards to the diagram you have shown but ‘14’ on T-800’s diagram looks to go straight through the box as one complete shaft.
The exploded view of the box is from an A3 Quattro. Everything is slightly smaller than the RS3 because it`s not handling the same torque but it`s just to give you some idea of the layout.of how it works.14 does go through the box as one complete shaft.My picci shows 2 as one is an alternative for different models.
Edited by 0120raptor, 05 April 2018 - 04:22 PM.
Posted 05 April 2018 - 05:06 PM
Neil.
Sorry i stand corrected mate going by Seans late's diagram.
The cut away diagram was confusing.
Edited by RS3Dell, 05 April 2018 - 05:10 PM.
Posted 05 April 2018 - 07:13 PM
Still no word from them and that’s 3 days they have had it
Edited by Arkious, 05 April 2018 - 07:15 PM.
Posted 05 April 2018 - 07:58 PM
No it goes into the diff. I give up.
Posted 05 April 2018 - 08:07 PM
Posted 05 April 2018 - 08:52 PM
So, 14 doesn’t directly drive the transfer box, but does pass through it. So that shaft could have been changed without changing the whole assembly if Audi had desired. Thankyou for clarifying that it does attach to the diff, I just looked at that last photo and it looked like it was attached to the large gear in the top left of the gearbox. Cheers for looking into this with me guys. I’m not too clued up with gearboxes, I’ve just been trying to fathom out where this issue is.
Posted 05 April 2018 - 09:19 PM
Gearbox classes now offered.£150 /hour.Only a few places left.
Posted 05 April 2018 - 09:33 PM
I must apologise I misread your earlier post when reading through earlier regarding the all faithful ‘shaft 14’ and feel like a pleb haha. That what I get for reading them as I got to work!
Shaft 14 could have been changed by itself but if it`s suffered bearing failure chances are that swarf has damaged other parts in the gearbox as well as the transfer box..
Posted 06 April 2018 - 12:33 PM
Posted 06 April 2018 - 04:11 PM
Well apparently there is nothing wrong with it
Nothing wrong with what?
Posted 06 April 2018 - 04:27 PM
Have you guys listened to the video and compared it with your own to see if your cars do the same?
Posted 06 April 2018 - 05:02 PM
Remove the air box and give the mount a good old shake.
Edited by JayRS3, 06 April 2018 - 05:03 PM.
Posted 06 April 2018 - 05:32 PM
Hi Jay, yeah I had the whole box all out when I fitted my 034 (bit of a **** to get out to be honest), but it looked brand new and I tried to give it a good shake and it just seemed to do what I would have expected it to do. If you remember my previous thread I thought this was the cause then but because it sounds metallic and has only happened since the transfer box was fitted I started looking at the gearbox it’s self
Edited by Arkious, 06 April 2018 - 07:45 PM.
Posted 06 April 2018 - 05:42 PM
Just thinking outside the diff area. Have you checked your gearbox mount? Sounds like a flutter from the video which is what mine did when it started to fail. Only noticed under slow driving/low gears as that’s when everything is under more stress.
Listening to that Jay I tend to agree
Same noise I had when mine went to Macc Audi on its 2 month vacation.
Posted 06 April 2018 - 07:41 PM
Ohh really you both had the same noise? that's put a smile on my face if its just that!
how much are they and where can I get them from? are they a big job to fit do you know? I remember looking when I had the box out thinking it looked like a right pig of a job. I really appreciate all the help, I am at wits end with it and its really taking the enjoyment out of the ownership. I expected niggles but this has dragged on since I bought it, just in a different light now compared with how it used to be.
Posted 06 April 2018 - 07:42 PM
mine does it anywhere up to 40mph and only on corners. I can deliberately make the noise by coming on and off the accelerator on a bend as I did the first time in the video. However the rest of the sounds was just as I had the accelerator lightly pressed when cornering
