Heavy frost over night meant I had to de-ice the car and had it running for several minutes before setting off. At this point I noticed the passenger side wing mirror hadn't cleared but drivers had.
Drove to work parked up and then thought I'd check the mirror adjuster was working, nope! Then went around to the passenger side and found both doors to be locked and subsequently found that they can't be opened from inside!! Great.
I haven't dared try the windows in case of them temporarily working and get stuck down but chances are they won't work either!
I've scanned the car with VCDS and no surprise there's several fault showing on the different modules but the two recurring fault numbers are 01332 & 01333 and relate to the door control modules.
Other than a quick scan, the dark and weather has meant Ive had minimal time to check over the basics like fuses but wondered if some one can point in the right direction bearing in mind it must be something common to affect all of the passenger side?
See pics for screen shots of the fault codes and note mod 52 & 62 couldn't be reached (Ignore radio/nav I get that occasionally for some reason)
Edited by Mattjj82, 30 January 2018 - 08:53 PM.
