Forge Intercooler *HELP*
Posted 26 January 2018 - 12:29 PM
Any help would be greatly appreciated
Part Number FMINT4
Posted 26 January 2018 - 02:05 PM
Billy
I think Forge only make to order mate.
Edited by RS3Dell, 26 January 2018 - 02:09 PM.
Posted 26 January 2018 - 02:34 PM
I bought through Forgemotorsport direct. I'm assuming you have tried them Billy?
You could always look at the Wagner Competition Evo 3 intercooler as another option?
Posted 26 January 2018 - 03:57 PM
Posted 26 January 2018 - 05:21 PM
Personally I would wait the build quality is superb and you get a decent crash bar
not soem fuddled together thing
18 Plate St2 TTRS, Roadster, 20" OZ Indy HLTs, Forge IC and Hard pipes, Audi Carbon Mirrors, Automotive Passion spoiler, Side skirts and front air vents. Scorpion full system all tuned by MRC
Posted 26 January 2018 - 07:13 PM
You get all that with airtec too
Posted 27 January 2018 - 07:51 AM
Posted 28 January 2018 - 07:44 AM
I know the above is not a test done on an RS3 but at least it’s a test of Airtec vs Forge intercoolers. Basically I’ve heard on Ford, VW and Vauxhall forums that they are just as good and better value. Personally I think Forge units are good but I’m open minded always.
If I was choosing an intercooler I’d go for an intergrated Engineer one all day long because I saw tests where the outperformed several others. Sadly I don’t think they are available for your model yet. Regal Autosports use IE on 500hp Golf R and Scirocco R conversations and swear by the test results.
If you go to a dealer unless you see test results you will often get poor advice. I have first hand experience from an owner who told me they make vastly different profit margins with different brands. The difference in price can sometimes be a larger profit margin only.
Posted 28 January 2018 - 08:54 AM
Any upgrade IC is better then the OEM one & the difference in performance between makes is marginal mate.
I'm running a Forge one by the way 😊
Posted 28 January 2018 - 07:42 PM
not sure if any help to you put everything you need in my for sale advert parts will be available tomorrow
http://www.audirs3oc...nversion-parts/
Posted 10 February 2018 - 09:11 PM
A little bit of internet info on potential intercooler options for the RS3 8V....
https://www.etuners....8v-intercooler/
Posted 13 February 2018 - 12:18 PM
Posted 27 June 2018 - 08:40 PM
I am looking at intercoolers myself now and wondered if anyone who has fitted the Forge unit to a FL had any issues? Does anything need to be cut and I heard something about opening up the front intake to take full advantage of an uprated IC, but not sure if this was for the Forge unit.
Posted 27 June 2018 - 08:47 PM
what about the latest pro alloy cooler? does anyone know anything about it? core type act...? pro alloy usually make good stuff.
Posted 27 June 2018 - 09:44 PM
I have the Forge FMINT4 being fitted to my FL car next week. I also had the same IC on my PFL car too. The only part that needs modifying as far as I know is the OEM crash bar but this is supplied by Forge as part of the FMINT4 kit. Sometimes the packing behind the front bumper may need removing to accommodate the thicker Forge cooler, you may also need to consider how you fit the OEM number plate holder as the brackets supplied by Forge are pants! I used some dry wall butterfly clamps which fold and spring out behind the grill when in place. I don't know if this will be the same for the FL car but I guess I will find out next week.
Posted 28 June 2018 - 06:07 AM
Posted 28 June 2018 - 06:59 AM
On the fitment of the number plate I have two filled in sections on the grill, I have a small number plate so
cut down the OEM plinth and fitted super strong magnets to both and it works a treat even in the hot weather
Posted 28 June 2018 - 07:40 AM
UK No plates do fit with no problems in the German No plate surrounds.
Edited by RS3Dell, 28 June 2018 - 07:50 AM.
Posted 28 June 2018 - 12:59 PM
Nice one Fivelotfan, I will be looking forward to reading your follow up post on this. What software are you using and have you done any other mods yet?
Ran two facelift cars on Surrey Rolling Road dyno last week. One car completely stock (friends car), and my car with the HG Motorsport intake pipe and K&N high flow filter fitted. Results were not as expected except for the slightly optimistic dyno numbers (always around 2 or 3% high on average at SRR) but we went to get an 'apples for apples' comparison anyway.
Steve's completely stock car (the green plot line at the top) ran 422bhp with decent torque (around 410lbs/ft) while my car showed good promise with the HG intake with significant gains over stock right up to 5K rpm. It's at this point where my car didn't seem to like something and pulled timing which can be seen at the red plot line losing around 60 to 70bhp before climbing back to a respectable 415bhp at 6800rpm and 420lbs/ft torque.
The obvious difference between the two cars was the HG intake and filter on my car. I have opted to strip these parts off and get the car dyno tested again this weekend to prove if it's just the performance parts not being optimized, or maybe I have an underlying problem with the car.
Both cars are off to MRC next week for remapping, one car will be stage 1 (Steve's) and prior to mapping mine it will have the Forge IC added and hopefully the HG intake + K&N too. I may also consider fitting a downpipe in a month or two.
Edited by Fivepotfan, 28 June 2018 - 05:10 PM.
Posted 28 June 2018 - 11:38 PM
I’m looking at the same set up you but may go APR map due to having a dealer 5 miles away.
