Right lads will 19 x 9.5 fit the 8P RS3?
I'll need to double check what offsets are available.
The question i'm going to ask back is why wouldn't you want to fit wider wheels and tyres?
Edited by bazf, 11 January 2018 - 02:26 PM.
If the RS needed wider wheels Audi would have fitted them with the appropriate body work to match.
But as a fashion statement knock yourself out mate !
Edited by Mattjj82, 11 January 2018 - 06:40 PM.
The RS needed better brakes but Audi never fitted them
The Brembo's are fine its the pads & disc material thats the problem !
The RS could have done with the 8.5J wheel fitted as standard up front but didn't. They only fitted a smaller 225 tyre in the rear to save having to change the arches or offset of the wheel
Matt.
The 8.5J was an option on the front on both the 8P & 8v but they never changed the body work at the back as a cost cutting exercises
With the right tyres there's loads off grip on these RSs
Anythings more grippy than the stock Conti sc 5ps they fitted as standardMatt.
Edited by Mattjj82, 11 January 2018 - 06:55 PM.
As you say with decent tyres (MPSS/PS4) grip is so good you're worried about stuffing the diff!
Matt.
Something has to give mate
Pads are crap yes but the discs are aren't handed so the cooling vanes aren't correct and theres only air ducts on one side. All cost saving measures by Audi..tight as a ducks arse.
The RS is the first Audi I've owned I expected a little more from them tbh on the top model
Matt.
I didnt warp the discs at Castle Combe but they did take a hammering the same can't be said for the EBC reds
As our front discs are unique to the RS3 i think Audi use the same material as the rest of the Audi range & just not up to the job mate !
Think about it logically though....Oh dear, looks like iโve found the forums Smart Arse today.
Edited by T-800, 11 January 2018 - 09:08 PM.
Standard RS3 has 8J 50 ET 19โ rears with 225 tyres.....
You want to put a 9.5J rim on which will need maybe 265/275 tyres on to look anything like sane..
The rim alone (if you adhere to 50 ET) will be 19mm closer to the strut and 19mm further out.....
Nuff said !
