Gearbox software standard vs tuned
17 replies to this topic
Wrekka
Wrekka
  • 44 posts
My car is running stage 2 APR engine map but presume the gearbox is standard but am unsure.
My car will not allow me to put it into second gear from a standing start-is this normal? Other auto cars have always allowed me to go into second gear for setting off but the RS3 only goes in once moving.
With regards to a gearbox map do APR actually do one?
cheers!
Why would you want to set off in second gear.?????????????????
To stop 1st gear wearing out ?🤣
Neil
My thoughts but wasn't going to ask why mate  :o
Wrekka
Wrekka
  • 44 posts
Setting off in second gear in snowy conditions reduces chances of tyres slipping.
When I drive the m3 in very wet conditions and want to set off quickly always put the car in 2nd gear to set off -less chance of wheels spinning.
Edited by Wrekka, 24 December 2017 - 10:13 PM.
Pil5burydoughboy
Pil5burydoughboy
  • 473 posts
  • LocationAberdeen
You're not in an M3 tho.
Hold on you've got 4 wheel drive & there great in the wet & snow if you don't drive like a cock !
Leave in D let off the brake & the RS will creep forward without any throttle then once moving just touch the throttle lightly & your be fine 😊
It's all about being gentle and smooth !
Wrekka
Wrekka
  • 44 posts
Yeah just seems a very fine line between swift and full boost power with this APR map.  Can be tricky dodging out of junctions sometimes as can go on full power too easily and you end up looking like a hooligan!
So does the RS3 just not go into second gear then from a standstill? Can someone try it on theirs please for a comparison? Cheers
May be you really do need to control your right foot as my RS is on a MRC stage 2+ mapping & doesn't have the traction issues or concerns your expressing mate.
On light throttle pull always my changes into 2nd nearly straight away I'm also running on MPS4s tyres 😊
Edited by RS3Dell, 25 December 2017 - 06:13 PM.
Could possibly be the throttle pedal sensor. It`s just two linear pots. If one goes faulty it can give you "on or off" throttle. VCDS will check this for you.
Wrekka
Wrekka
  • 44 posts
Ok will look into this in the New Year
bazf
bazf
  • 92 posts
  • LocationAberdeenshire
Just put winter tyres on.  Problem solved.  Quattro plus winter boots is awesome.
Tbf when we left the services for Castle Coombe it looked like you were trying to run me over you set off so fast ;)
APR don't offer a gearbox map for us.
I have teh MRC DSG tune and I really like it, They custom adjusted the Sport setting for me so it doesn't hold the revs for so long. This is great for general spirited driving but most of all for cruising. Its like D mode but only bags more power and torque and no constant high revs.
Wrekka
Wrekka
  • 44 posts
Nice one cheers
TX
Sorry mate I wanted to get the jump on all the fast boys 🤣
TX
Had to re-read that Dell...... thought it had an s in there
Stop it !........You behave mate  :P
