I just replaced the front top mount bearings as the mount it self don't really wear !
Edited by RS3Dell, 10 July 2017 - 01:19 PM.
RS3 8P - Daytona Grey - Stage 2+ - 430hp - DSG Map - Turbo Back Milltek Exhaust - Wagner v3 Intercooler - 034 Motorsport Intake - 034 Motorsport ARB - 034 Motorsport Dogbone insert - 034 Motorsport Top Mounts - Bilstein B14 Coilovers
I hate the standard suspension as it just so uncomfortable .... so .. what do people recommend for road use ?
I've seen that the B14s seem to be a popular choice - so would these fit my requirements do you think ... or ... does anyone have any experience of any other good solutions ?
Thanks all.
As someone who is also struggling with the uncompromising stock suspension (your post could have been my post - I also don't want to go lower!), I'm very interested to see if you made the jump to B14's (or 16's) and if so, what you made of them. I see conflicting information on going to coilovers, with some reporting improved comfort but the majority saying the ride is firmer. I would really more compliance in the suspension.
All I would add is that Awesome recommended the KW V3's.
Edited by Nillamb, 02 August 2017 - 10:11 AM.
KW V3 are great but HARSH!
B14's are a great improvement over OEM...you have to accept that there has to be a compromise between comfort & firmness. Yes the B14s are firmer and going over normal roads at normal speeds, you do feel the firmness but the B14's actually reduce the crashiness and thus are more comfier IMO
Hope that helps
Ive had a rear OEM spring break at 22k so i wanted a better quality springs/dampens
I was looking for a more compliance ride & drop the front 25mm but keeping the rear standard ride height & ive used Eibech in the past with good results
But Eibach only do fronts springs for the RS3 8P.So i looked at making up my own kit using 2lt TFSI Quattro rears & Bilstein B8 shocks.
I spoke to Eibech UK they gave me the part No for the front RS3 springs & TFSI rears,i ordered Bilstein Quattro shocks but then found after a dry build the front struts 25mm are too long for the Eibech springs our RSs are quite low !
I then spoke to Bilstein who were helpful & said they could shorten the front shocks by the 25mm required which they did.
When i fitted the Eibech rears i found the car sat 10mm higher than standard
I gave up on that project & fitted B14 with the ride height as i wanted but the are very firm around town & good dampening at speed
The front spings ive now sold & have the Bilsteins B8s on Ebay with the Eibach TFSI Quattro rear spings
Hope this is of help mate.
Edited by RS3Dell, 02 August 2017 - 06:10 PM.
I've not done anything yet as alas have other priorities at the moment.
I have made the decision to go with the B16s though if I do upgrade as it appears they are the ones that you can 'soften' the ride on.
Enjoy the car though .. even if it is a little stiff at the moment
You can't go wrong with the B16's, firmer than stock but no crashiness and find your sweet spot in the height and ride adjustments
Been consideri g b16s or kw v3 perhaos with the ddc option. Seems like the RS3 is staying with us some time as wife dosnt want anythimg else out there including the latest RS3. Since the car is now used to ferry the kids around in the would love the flexabilty of a softer ride l, but then switch ot up if I fancy the odd track day. Never considered air ride before as i thought i was all show and no go, but doing a bit of reading it appears that that technologhy has moved. Anyone running airride at the moment? Interested in your guys opinions on various set ups as its an exoensive thing to get wrong!
Sent from my HTC 10 using Tapatalk
Hi sawda
You cant go wrong with the Bilstein B14s or B16s
B14s for price but non adjustable damping,B16s all singing & dancing damping adjustment & both with a good range of ride height
Sorry to re open this thread but has anyone ever tried the Ohlins equivalent?
If I could just get the ride a bit more comfortable I think I could keep it a long time. On standard set up it’s so harsh on a typical British b road
What's the overall comparison/thoughts on comfort and handling for the B14's vs OEM set up?
OEM is very crashy imo - feels more harsh than the KW V1's on my Golf R previously.
Thinking of B14's in the near future.
Does anyone know if MSS provides TUV certificate, for their springs to be legal in Germany and EU?
