In order to clear the front RS3 calipers I used a 5mm spacer. So the total offset on the front is actually ET37.
On the rear no spacer was needed to clear the calipers but I used a 3mm spacer anyway for the arch fill and looks.
No rubbing or issues at all with the RO2 oem tyres. Running 255's on the front and 235's on the rear.
Another plus is that these wheels are Flow Formed which means they are super light. They weight just 9.7kg. Compare that to the 14kg 8j, and 14.5kg 8.5j Oem Rotors it's a massive unsprung weight saving.
I'm really happy with them. Better than I had expected and really work with the Alu Pack.
