Exhaust flap
Posted 13 March 2017 - 10:03 PM
Am I right in saying that the vacuum is pulled during non sport mode on the exhaust valve and releases the vacuum when the "S" button is pushed?
So if I was to pull off the vacuum hose it would leave the flap half open (sports mode effectively)?
Posted 14 March 2017 - 08:18 PM
Does anybody know any cure to stop the rattle on the valve other than disconnect it, surely there must be some kind of spring on the actuator arm of the valve, can we not replace that?
Posted 14 March 2017 - 08:21 PM
Don't think it's a spring mate, purely an arm connected to the actuator and the other end on the flap arm.
Maybe it's flapping because the arm from the valve has gone loose, so there's no tension (to keep it silent). Try replacing that.
Edited by JayRS3, 14 March 2017 - 08:23 PM.
Posted 14 March 2017 - 08:32 PM
Macclesfield Audi replaced it under warranty as they said no parts could be ordered separately.....
They replaced the whole rear setup.
Posted 14 March 2017 - 08:56 PM
Thanks for confirming.
I'll be honest when I had my car on the ramp on Saturday my valve looks completely different to the ones in your picture, is this a miltek or something like that?
It isonly a slight rattle and I only heard it because it was at idle in the multi storey at merryhill shopping centre.
From what I could see, the arm for the arm comes out the bottom of the valve sort of like a piston almost, I assumed the spring must be inside there to put pressure on it so that it stays down / open when there is no boost.
Perhaps I'll go about changing the vacuum hose first, make sure this isn't blocked up as it wasn't bunged up when I found it dangling or maybe it could have a small hose in it and is loosing pressure.
Posted 14 March 2017 - 11:01 PM
Posted 15 March 2017 - 09:06 AM
Posted 15 March 2017 - 09:23 AM
Yes aftermarket mate. I've got my original back box for sale if you need to replace it should the flap annoy you.I'll be honest when I had my car on the ramp on Saturday my valve looks completely different to the ones in your picture, is this a miltek or something like that?
Posted 15 March 2017 - 09:53 AM
Posted 08 July 2018 - 09:18 AM
Posted 08 July 2018 - 04:04 PM
It should open initially for about 20 seconds then close.
Posted 08 July 2018 - 05:59 PM
Yes Neil you are correct on that mate.👍
Posted 11 July 2018 - 11:39 PM
After that I can’t seem to notice a change when the SPORTS button is pressed.
How do I go about removing this valve so it sounds a bit louder all the time?
BTW it’s a 8P!
Posted 12 July 2018 - 01:37 AM
If your running a stock exhaust then just get your head under the exhaust a pull off (tape up the end) the vacuum hose that pushes onto the valve which will mean the exhaust will stay permanently open. Under normal conditions the valve is closed, when the S button is pressed then the valve opens. The vacuum keeps the valve closed (normal conditions) no vacuum will be sports mode.Mine sounds loud on initial startup for about 20/30 seconds and then calms down.
BTW it’s a 8P!
Here’s an example of my aftermarket system but the same principle applied
If you still have no change any noise then you may have a faulty solenoid which is a replaceable part. Or your valve is seized, see if you can move it physically when when you remove the hose.
Edited by JayRS3, 12 July 2018 - 01:39 AM.
