Best Coilovers for RS3?
Posted 24 May 2016 - 08:10 PM
Any advise is much appreciated, thank you all in advance!
Posted 25 May 2016 - 07:31 AM
Had a look at Bilsteins and KW and elected for Bilsteins in the end based on previous experience of KW V3 on RS4,, they were a bit too harsh. The B16 kit which is rebound adjustable is excellent although not without its flaws as all coil-over kits are. Whilst it now makes the car handle like a go cart on cold days or first thing in the morning it is noisy / squeaky until the oil in the shocks warms up and can as a consequence be initially crash or poor surfaces.
B16 ride control would have been fantastic but then I wanted a 'fit and go' product rather than one I was playing on with and there is a large cost difference. If I do track it takes a minute or so to change the settings on the coil-overs by hand. If its just looks you are going for lower springs would be the way to go but if you want looks, improved ride and handling coil-overs is a must.
Posted 25 May 2016 - 11:26 AM
I have the same kit as P_G above, and can thoroughly recommend it. I have driven an 8P with lowering springs and it was very disappointing - looked great but roadholding no better and ride choppy and harsh. Lowering springs on 8V with mag ride seems to get good reports though - I suggest you try all the options before you choose
Posted 25 May 2016 - 12:31 PM
Posted 25 May 2016 - 12:45 PM
I'm on the same band wagon with this. Bilstein or KW. Ran KW V3's on previous cars and they are sublime. Decided to defect on my RS3 though and went with the Billys. Didn't splash out on 16's though decided to go with the B14 Bilstein kit and I've got to say it's transformed the handling of the car completely (coupled with the 034 Motorsport rear ARB).
As booker says though, they do firm up the ride quite a bit and are particularly harsh first thing in the morning when cold.
If like me you don't really care about the harshness then they are a great modification to do.
Posted 25 May 2016 - 01:27 PM
Posted 25 May 2016 - 02:08 PM
i ran bilstein on my RS4 was great but after a while was too hard to live wit everyday
stage 2 8p 445BHP 518lb ft
Posted 25 May 2016 - 02:32 PM
You definietly have to adjust the rebound on them on a regular basis to get the best out of them, if you leave it in one setting all the time for whatever reason is starts to get a little harsh, Playing around with the dial settings and therefore the pressure in them and also jacking the car up so the suspension drops somehow invigorates the shocks. When its working properly the ride is so much better / pliable than OEM
Edited by P_G, 25 May 2016 - 02:32 PM.
