Anyone had a stone lodged in brakes?
Posted 04 January 2016 - 07:40 PM
I pulled up and put it in reverse, noise was even louder. Pumped the brakes a couple of times but any slight movement forwards or backwards in the car equated into the most ear piercing utterly piercing screeching squeeling noise I've ever heard... Sounded like Steven Hawkins going into a crusher.
Rang Audi Assistance up who described the noise back to me almost instantly. One of their "technicians" quickly called me back and had me very slowly drive forward turning the wheel left and right in quick succession so I was snaking. Then repeat in reverse, he said often you can dislodge the stone, sure enough on the second reverse it pinged out and the noise had gone.
A crowd of builders had formed watching me which was embarrassing but there you go, apparently Audis are prone to this?
RS3 8P - Daytona Grey - Stage 2+ - 430hp - DSG Map - Turbo Back Milltek Exhaust - Wagner v3 Intercooler - 034 Motorsport Intake - 034 Motorsport ARB - 034 Motorsport Dogbone insert - 034 Motorsport Top Mounts - Bilstein B14 Coilovers
Posted 04 January 2016 - 07:48 PM
Never thought a stone was possible - only heard about it in the RS unfortunately.
Posted 04 January 2016 - 08:03 PM
Always when leaving work and there's loads of people looking
Usually comes out with turning the steering side to side when moving slowly.
Posted 04 January 2016 - 08:15 PM
Posted 04 January 2016 - 08:27 PM
Had a large stone jammed in one of the holes in the front N/S disk that was smashing into the calliper. Had to pull over, remove the wheel and dig it out before too much damage was done.
Also had a stone stuck in a rear brake on my old A3 Sportback giving much the same problem that you had. Pigging annoying but yes as others have said quite common on Audi's.
Posted 04 January 2016 - 08:31 PM
However had some s h i t pads lodged in me old 8p
Sent from Cyberdyne systems
Posted 04 January 2016 - 08:51 PM
Never had a stone.......
Harsh... but so, so true if you're talking about the nasty Audi/ Pagid's...
Posted 04 January 2016 - 09:01 PM
Had this a few times myself.If you bang the shield with your hand it usually dislodges the stone.
Posted 05 January 2016 - 11:11 AM
I have this ALL the time!! I have a gravel drive to the house and they get picked up in there at least twice a month. As said a good tap on the shield gets them out!
