GROUP BUY RS3 uprated anti rolls bars ...group buy will close on the 23-08-14 ...
131 replies to this topic
  • 1,658 posts
034 motorsport rear arb £243 delivered to u (uk)
H&R arbs £360 delivered to u (uk)
with a minimum of 5 confirmed/deposits paid orders for this to go ahead on the 034 motorsport arbs no minimum order on the H&R'S ..just stick your name down ...thanks ...
Edited by RS3-KEL, 16 August 2014 - 11:53 PM.
MB RS3
MB RS3
  • 156 posts
Very tempting... What are the pros and cons (if any) of this ARB?
Mal
Chris
Chris
  • 339 posts
All pro's from what I can gather with very few if any drawbacks :)
  • 1,658 posts
The 034Motorsport Rear Sway Bar is engineered to be used effectively with the stock front sway bar. No upgrade in the front is needed or required. The addition of a stiffer front bar introduces even more push, requiring an even bigger bar in the back. With the stock front sway bar and upgraded 034Motorsport Solid Rear Sway Bar, body roll is virtually eliminated while turn in and off throttle oversteer are greatly improved.
The sway bar rate is adjustable via the adjustment holes. The two holes closest to the MOI of the bar are the "stiff" (423% stiffer than stock) setting, and the two holes farther out are the "soft" (362% stiffer than stock) setting.
Edited by RS3-KEL, 03 June 2014 - 09:29 PM.
  • 1,658 posts
I will also be doing a group buy on the h&r arbs if any members are interested prices to follow...
Klauster
Klauster
  • 749 posts
I already have one, one of the best mods I have done
Aircool2012
Aircool2012
  • 34 posts
Is there much difference between the H&R and 034? I might be interested.....
Price wise yes, H&R is 2 bars and twice the price. Rear ARB is all you need on stiff setting to reduce / near eliminate over-steer. RS3-Kel, if you are speaking to Laslo you can ask him whether I get any kick-back for extoling the virtues of their bar on here! ;)
Edited by P_G, 04 June 2014 - 03:21 PM.
MB RS3
MB RS3
  • 156 posts
Does it compromise ride quality at all? On "stiff" setting it doesn't induce oversteer does it?
Mild lift off over-steer yes and it does make the chassis a little more rigid but not uncomfortably so. That's why I only went for rear as I would think front and rear ARB's could make it very hard.
  • 1,658 posts
The h&r arbs are £360 delivered :)
Chris
Chris
  • 339 posts
I'm in, Chris 034 Motorsports rear bar :)
  • 1,658 posts
1 - RS3-KEL
2 - Chris
Edited by RS3-KEL, 05 June 2014 - 11:01 PM.
SapsRS3
SapsRS3
  • 57 posts
The group buy still going ahead on the 034?!
If so put me down!
FletchRS3
FletchRS3
  • 388 posts
  • LocationNewcastle
Put me down as well if it's still happening.
  • 1,658 posts
1-RS3-KEL
2-Chris
3-SapsRS3
4-FletchRS3
5-martynrich67
Edited by RS3-KEL, 06 August 2014 - 10:06 AM.
martynrich67
martynrich67
  • 112 posts
  • LocationEast Riding of Yorkshire
Put me down for an 034 please :)
Pm me details on payment of deposit and I'll get it sorted ASAP.
CHEERS.
Klauster
Klauster
  • 749 posts
i would suggest getting a spare set of brushes at the same time if you are planning on keeping the car, mine are shot after 15k miles
martynrich67
martynrich67
  • 112 posts
Might be worth asking the supplier if they can provide bushes too :) group buy on them ;)
Are these limited to the RS3 or would they add on other models too John?
