Updated injectors?
17 replies to this topic
Renga
Renga
  • 69 posts
  • LocationSweden
What update injectors are the for the TTRS/RS3?
Is there a newer injector revision/version that you can use in the 8P from the latest modells?
Is 07K906031L the latest?
Any aftermarket to recommend?
Edited by Renga, 07 September 2017 - 01:51 PM.
  • 1,199 posts
I believe the the 8v one's are now used as a replacement for the 8P.
2012 Phantom Black, Bucket Seats,Optic Black Pack, MRC Stage 2,+ DSG Remap, Forge Intercooler, Autotech HPFP, HG Motorsport Intake Pipe, Pipercross Airfilter, 034 Dog Bone Mount, Fully Decatted OEM Exhaust, 443Ps 777Nm, Bilstein B14, 034 ARB.MPS4s,VCDs User.
alvareitor0102
alvareitor0102
  • 49 posts
"L" are the last ones.
RS3 8P APR Stg2+, Mini R56 JCW Stg2+, Ex GTI Mk5 K04 DSG, Audi RS6 Avant, M3 E46 SMG 4.1, Saxo vts 16v, Clio V6 Mk1.....
Renga
Renga
  • 69 posts
  • LocationSweden
The latest 07K906031L
2L-TFSI-RS3-TTRS-Injector-Upgrade-07K906
This is the Facelift 400HP version, looks a little different
07k906036
    Manning the Waffle Iron......
  • 8,537 posts
  • LocationFL RS3 Glacier White..............
I’d stay away from the FL ones and use perhaps the pre-Facelift injectors.
Don’t forget the FL engine with its higher output has been re-designed and now employs Direct & indirect injection (like the EA888 in the golf R)
Renga
Renga
  • 69 posts
  • LocationSweden
Anuone know the spec on the 8P/8V injectors?
Flowrate and so on?
  • 1,199 posts
Flowrate and so on?
Renga.
Can i ask why do you need to know the flow rate mate ?
The injectors are good for 550+ bhp or if you have a problem you check the flow rate like for like against the other injectors on your car.
Renga
Renga
  • 69 posts
  • LocationSweden
Renga.
i'm gonna send the injectors for cleaning and flow test and want to know the spec
Renga
Renga
  • 69 posts
  • LocationSweden
According to this calculator this is required for 550 Wheels HP
https://fuelinjector...flow-calculator
# of Cylinders  5
Fuel Pressure (psi) 1741
Engine Aspiration Turbocharged
Horsepower desired @ Wheels 550
Duty Cycle 90%
Injector Size Required Fuel Type Gasonline cc/min=139.97 13 lb/hr
Fuel Pressure PSI numbers from
Edited by Renga, 12 September 2017 - 08:49 AM.
  • 1,199 posts
Renga
What performance mods are you looking at doing mate ?
Renga
Renga
  • 69 posts
  • LocationSweden
Renga
Replace my LOBA500P for a TC600UE or TC640
  • 1,199 posts
Ah I now see why mate 😊 whoever supplying the turbo should know what injections or upgrades to use,That's the 1st place to ask. 😕
  • 636 posts
# of Cylinders  5
Duty Cycle 90%
Is that the correct flow rate ?
Petrol engines require 1/2 lb of fuel per horsepower per hour for maximum power.
At 550 HP that equates to 275 lbs of fuel per hour total flow. Divide that by 5 injectors = 55 lbs/hour. Turbo engines running rich at the top end would need even more.
Edited by 0120raptor, 12 September 2017 - 06:44 PM.
alvareitor0102
alvareitor0102
  • 49 posts
In this case is easy: just contact Tobias in HPerformance, He can tell you what inyectors you´ll need for the TC60 Ultimate Edition.
Renga
Renga
  • 69 posts
  • LocationSweden
All i wanted to know was witch is the latest rev for 8P injectors and the flowrate for them...
  • 1,199 posts
Sorry mate but by the looks off it no one knows the flow rate 😕 as for the the latest injectors do as I've done which is speak to an Audi parts dept for your answer.
There's a new member Nath from Australia whom has a Tomcat turbo fitted PM him & ask the questions you need to know.
Edited by RS3Dell, 13 September 2017 - 01:50 PM.
Renga
Renga
  • 69 posts
  • LocationSweden
Sorry mate but by the looks off it no one knows the flow rate as for the the latest injectors do as I've done which is speak to an Audi parts dept for your answer.
Have all the info i need on The Tomcat´s thanks and i now give up the search for the flowrate, i'm sending in the new "L" injectors for a flow test next week.
  • 1,199 posts
Sorry no one could be off any help over here 😞
We don't have any experience with the Tomcat turbo over here mate.
Your find out when you remap your RS whether the new injectors are up to the job with the Tomcat turbo.
Edited by RS3Dell, 14 September 2017 - 08:42 AM.
