KW DDC ECU coilover kit for RS3 (8V)
coilover suspension lowering
2 replies to this topic
KWAutomotiveUK
KWAutomotiveUK
  • 3 posts
In 2012 KW Automotive launched its DDC (Dynamic Damping Control) range of coilovers – a revolutionary technology that allows the damping characteristics to be adjusted at the touch of a button or, when combined with the ECU W-LAN module, individual adjustment through a smartphone app.
The KW DDC suspension is based on our inox-line coilover with the addition of an electronic damping control unit. Once paired to an Android/Apple device, the DDC app allows up to five individual setups to be programmed which can even be shared via e-mail! In addition to the standard damping settings (Comfort, Sport and Sport+), the DDC app also allows each coilover to be individually set with a variable of 0% (maximum comfort) and 100% (maximum sport). With the settings transferred in milliseconds, you’ll instantly notice the difference!
The KW DDC update is available easily via the Apple App store or the Google Play store and will be completed, depending on your Internet connection, within a few minutes.
http://www.kwsuspens...kw/info/kw_ddc/
Now also available for the Audi RS3 (8V) without electronic dampers from factory
Part number: 39010055
RRP: £2858.00 including VAT
WLAN-Kit Part Number: 68510276
RRP: £272.00 including VAT
peazz
peazz
  • 532 posts
Any discount for forum members?
xarjie
xarjie
  • 1 posts
How is the Kw V3 DDC integrate with the existing Audi magnetic ride function?
Is the KW DDC coil fully integratable with the Audi OEM system 1) without giving fault codes and 2) can be controlled and changed via audis drive select? Or is the Coil's DDC switched through an additionally installed button?
Thanks
Also tagged with one or more of these keywords: coilover, suspension, lowering
